| You could also use coverage logging on the FMX, a switch in the cab, a relay or two, and a lift switch to allow you to turn on and off your system at will, it could turn off while raised, and also log a coverage map (paint) on the FMX.
All inexpensive and you wouldn't need to buy any expensive cables. All the cabling and switching you could make yourself.
The poster above is correct, FIQ doesn't need any unlocks, BUT Variable Rate by prescription does.
Manual rate control through FIQ does not need an unlock. | |
