Search Forums | Classifieds (187) | Skins | Language
Trimble VRS Corrections
neo_ag
Posted 1/21/2023 21:23 (#10052289 - in reply to #10052228)
Subject: RE: Trimble VRS Corrections
northeast ohio
Here are the instructions we received several years ago. Have now switched to PIQ but the app page setting is the the same process. Then you set up each device on WiFi page. It may also be advisable in areas with lots of homes to set up the display to not actively search for WiFi connections or ignore networks. BIL had quite a bit of trouble with this near allotments. We do experience issues on one farm where X-fill kicks for 15 sec to a couple minutes in because of cell service.
** After code QR code is scanned in app central. There is modem services app on app page, open app and the top setting should be turned on. Then in FM1000+ app add the VRS plug in under add remove programs this will give you your VRS setup.**
We use either Hawking Technology HD65U USB Hi-Gain or Panda Wireless PAU06 300Mbps Wireless N USB Adapter With High Gain Antenna. Run not only corrections but autosync through the wifi connection. The beauty of the VRS unlock is that the host device can be whatever offers a hotspot. There is a notice out about newer phones that you need to adjust a setting on them to pair with the display.
Edited by neo_ag 1/21/2023 21:32
