| Having troubles with performance monitor on our 8300. Doesn't update any real time information. For example it will read 2.5km/hr and stay at that until i push the speed button then it will update to current speed whatever that may be. Does the same with PTO speed as well. If you start PTO will read 0 rpm, then push button and it will give current speed but remain at that speed even if engine revs and therefore pto revs change. Push the button and it will update... Any clues guys as I'm not real keen on the AU$2000 replacement option. Thanks | |
