NW Missouri | We recently bought an M125 on an auction. On top of the motor there are some of those big PAL fuses in blocks of 3. The one closest to the cab has a big wire coming out of the bottom that is hot, but isn't hooked to anything. It doesn't look like a recent break, so I'd say it's been unhooked for quite a while. I'm thinking it goes into the relays or whatever they are that are directly behind that fuse block. The wire is the right length, has the right bend, etc. Looks like maybe the relays are for the manifold heater? Anyway, if someone could confirm that this is where this wire should be attached, I would appreciate it. TIA.
(125-1 (full).jpg)
(125-2 (full).jpg)
(125-3 (full).jpg)
Attachments ---------------- 125-1 (full).jpg (108KB - 991 downloads) 125-2 (full).jpg (106KB - 988 downloads) 125-3 (full).jpg (127KB - 967 downloads)
