| Unless you keep that baler power washed religiously, that break was from lack of grease. Should be grease a half inch thick all the way around the tube coming out. Grease every 300-500 bales or daily. Been running deere since the 530s and never had that problem. Couple 567s north of 30k that if it was a weak point they would’ve gave out by now. Also can be caused from prolonged running with one tension spring broken. Hope it didn’t tweak anything too seriously for you and it’s back in service for next year. | |
