Posted 12/2/2022 09:31 (#9961227 - in reply to #9961215) Subject: RE: Adding header height to 9500
Faunsdale, AL
Very little if you can get it all off a scrap machine. There would be the valve back above the main valve stack on left side and a board plugged into the main board beside the cab door.
I expect the wiring harness is already mostly in place, but I’ve never seen one without it.
