Posted 7/3/2009 22:06 (#764838 - in reply to #764737) Subject: RE: Slugs just won't quit-over the row application
"They were using 1kg per hectare which is close to 1lb per acre. That's a really low rate but I failed to ask if it's the same formulation we have here."
I am thinking that cost is approx. $1 per lb, is that correct? If so, if you can use it at 1 lb/ac as a preventative insurance, you can start to really look at it. Agree?
