South Central Illinois | I could use a set of used, “RedE” Vertical Till Coulters. I just want to cut out the center with a water jet, to use as a spacer. 50 of them is what I need. RedE Preformance Ag Products manufactured by Farmland. Used Coulter’s would have a center that is the exact size that is needed. I probably could get the whole thing cut with a water jet. Just thought I’d check here to see if anyone has any available? |
