Search Forums | Classifieds (8) | Skins | Language
Putting JD ATU in New holland Cr 9060 combine
GcDm2010
Posted 7/30/2022 20:33 (#9773254 - in reply to #9773011)
Subject: RE: Putting JD ATU in New holland Cr 9060 combine
SOIL
The hub I have for most CNH tractors, Case and NH, around year 2010 is PF12140. I would assume combines are the same, but you'll have to pull your wheel off and find out for sure.
Pick your anti-rotation kit from here.
https://partscatalog.deere.com/jdrc/sidebyside/equipment/3833489/ref...
The harness I use is this one from AgExpress. https://www.agexpress.com/john-deere-greenstar-2-3-universal-atu-300...
I use an ATU and 2600 in my older Deere combine and it works very well. You will have to do some calibration and other adjustments until you're happy with it, but the new ATU 300 makes it easy enough and it's almost as good as integrated.
