Australia | I marked out the paddocks at cropping time on EZ500, using RTK, with an seeder implement of 9.14 and 3 headlands. Using the same EZ 500 in spraying tractor, i select the paddock number, which has a implement width of 27.43 and select 2 headlands.
I do the firts 2 headlands and its works fine but when i turn around to go down the first swath 1, it overlaps 1/3 of the headland 2, so we should be over another 9.14m. Why does it want to do this? any help would be apreciated thanks | |
