Posted 6/25/2009 19:20 (#756970) Subject: Ontrack 2 and Spra coupe steering column
Callao, Missouri
The coupe's steering column is spring cushioned (normally extended all the way but will slide in if pushed on). I'm planning to move my ontrack2 onto it soon, how should I approach this since the brackets are supposed to be made for a non telescoping column? Ez steer guys should have the same problem- keeping the wheel in position for drive contact.
