NESD | Need to go thru monitor and check all set-ups and calibrations, make sure boom is set to 90 ft if that is what you have.
When set to a rate the system uses the flowmeter and speed sensor(Radar or Wheel Speed) to determine speed to run the solution pump and it monitors pressure but does not use it for any calculations, when set to manual spraying the system uses pressure only and monitors the flowmeter and speed but does not use them. | |
