Delete
torn
Posted 5/19/2022 13:19 (#9666629 - in reply to #9666556)
Subject: RE: Pro700 prescription
roaming
If your Rx was accidentally written incorrectly (i.e. a rate of 30,000 with a unit of ksds/sc (=30,000,000 sds/ac), or vice-versa 30 with a unit of sds/ac instead of ksds), you can use the Rx Scale Factor in the display to adjust the Rx so you don't have to go back to the house to fix it and re-export.
