New Brunswick, Canada | Should be common rail so ecu flash or chip.
Is it safe? Are you weighting it down for tillage? There is bigger axles in the larger sizes. If just doing pto work you will probably be ok.
Agco stacks more clutch plates in the reverser and pto as the hp goes up so you will reduce the lifespan of them using it hard obviously.
Edited by slowzuki 5/14/2022 08:36
