Search Forums | Classifieds (72) | Skins | Language
NTRIP changes fix to 'unknown' every 5 seconds
swenzel
Posted 5/14/2022 08:24 (#9659919 - in reply to #9659834)
Subject: RE: NTRIP changes fix to 'unknown' every 5 seconds
NW IL
In my experience port B is not the easiest to set up and manage. You can go into port b via ag remote (or via RDI screens of pro700) but the settings do not often save correctly. It typically is reserved for NavII configuration.
Port C is correct for RTK input from external modems.
If you unplug 20/20 from the mix (and leave settings as they currently are) does the RTK appear to work correctly? Is it possible you have pinouts incorrect for B and it is interferring with RTK corrections on C?
