Iowa | Bobcat's 7 pin uses digital pulses. It won't work.There are adapter cables (expensive) that may accomplish what you want.
As a side note: If you desire 12 volt power, be careful where you get it from. You can't just find a hot wire with a test light and use it. Unless you are VERY lucky and happen to pick the correct wire, you will fry the controller (computer). Flip up the cab. On the left side near the top of the pumps there is a weatherpack connector specifically for accessories--use that. | |
