Central Indiana | Case IH 380 CVT pulling a case ih 24 row 2150 planter. Acres are coming out about 1.3% to high, which isn't a big deal, but would like to get it closer to ensure I don't run short on seed. I've verified population is about 1.3% to high also, but matches the acres planted. For example, if i have a field that is 100 acres and want to plant beans at 100k population the monitor will show i planted 101.3 acres and the population will be close to 101300 population per acre. Dealer thinks it needs a distance calibration, however, we can't find it anywhere in the monitor. If I unhook the planter then I can get the distance tab to pop up under calibration, however, it quickly disappears and can't be selected. Anyone know how I can calibrate this thing so it will be closer on acres?
Thank you! | |
