central - east central Minnesota - | WildBuckwheat - 5/3/2022 18:27 When is the last time the softener re-generated? Some re-generate every night, some every other week. I would try forcing a re-gen and seeing if it makes a difference. Its free, quick, and easy to try. Re-gen with cleaning agents to recondition or clean the resin contents. If that doesn't work - your resin will require to be removed and replace or cleaned with a harsher cleaning agent . . . . . . |
