North Central Iowa | Yes, the ez boom should be a drop in replacement for the raven. I’ve been using one for several years on my pull sprayer with an ez guide 500. Works great. Boom section control and automatic application rate control. Also use an ez steer to also steer the tractor. Currently on a JD8110 and a bestway sprayer. Before had in a JD4240 with a much older Sprayer Specialties that I retrofitted to work with auto boom and rate control. | |
