Butterfield, MN | The manual shows that each digit has a different purpose. The 4 I mentioned means that the control will work quickly until it gets within 40% of the target and then it will adjust more slowly to not overshoot. If this number is at 6, it will only work quickly to get within 60% of the value and then move more slowly, so this could explain why one bin could be controlling more slowly than the other. The 3 I mentioned means that the system will not control as long as the rate is within 3% of the desired rate, which helps prevent it from constantly hunting, which often makes the rate even less accurate. 3% is almost always a good place to be. | |
