Posted 4/20/2022 15:20 (#9623092 - in reply to #9623088) Subject: RE: John Deere rtk guidance lines? 2630 display.
NW MN
A another simplistic option is every field has a 90 degree & 180 degree line. You hand drive one pass on the on the edge of the field and then use the straight lines afterwards. Overlap is a issue but section control would eliminate some of it.
