Posted 4/3/2022 15:54 (#9595135 - in reply to #9594117) Subject: RE: 8870 Deere Piston
Townsend, Montana
Dirt_Floor_Poor - 4/2/2022 23:31
What exactly do you want to measure? They both used the 619 engine. The bore and stroke of each model was the same as far as I know, so the piston dimensions should match.
Piston bowl volume and compression height. Compression height should be nearly identical, but I'm thinking piston bowl volume is smaller.
