Alberta | Hi,
I was looking at getting a Canbus airtank for my drill from Amity and hooking it up to my pro600 in my tractor. They said it would run through Virtual terminal and they can do 4 product variable rate however Case only does multiple product variable rate if it is a Case tank. Does anyone know more specifics about this or if this is going to change. The fellow from Amity said the Dickey John display will run the 4 product variable rate but I want to use 1 monitor to reduce cab clutter.
Thanks
Curt
