NWKS | You don't have a leak. The oil that drips out of those tubes is draining out of the intake chamber. the oil drains into the intake when the engine is off or ideling from around the rings. Once the engine is wound up it just sucks up whatever oil there is and burns it. If that oil doesn't get away the engine and acculimates it can suck it into the cylinder and you will have a runaway engine untill it is all burnt. The only way to stop the drips that I know of is new cylinders and rings thats what fixed mine. | |
