Central Ohio | Well if they are both in the inside and outside are 880's try one in each. In fact, you can probably mount the ballasts (even temp) and have enough slack to switch the bulbs back and forth without moving the ballasts, though I have never been behind the grill on that tractor. Unless, you fell like you are really lacking some reach from your center two bulbs, I would think you would prob get more use out of the floods. | |
