Near-north Ontario, French River | Dont own one personally but there is one running in the area. What would you like to know? They use a simple metering roll ( like on a grain drill) to meter out material. Simple set up but as far as I know it lacks the ability to do variable rate, although most guys on here could easily modify the metering system to have the capabilty to. "Blower' fan is operated by PTO, but could be adapted to be run hydraulically. AULARI seems to stick the the KISS principle, they avoid all the electronics/rate controllers.(most) hyraulics and stick to gear boxes etc . the cart that I have seen is very well built and should last years. Main frame is steel but the 'hopper' is stainless steel. |
