Posted 6/8/2009 23:17 (#737666 - in reply to #737610) Subject: RE: 567 John Deere Bailer string
Rosemary AB, Canada
If the edge strings are popping off the edge of the bale you need to move the twine guides in. You can do some adjusting on the monitor but if you need to move it more then you have to do the twine guides in the side panels. The book will tell you how to do these adjustments. Oh and the drier the material that you bale ie straw, the farther in the string has to be. good luck
