Posted 6/8/2009 15:10 (#737084 - in reply to #736336) Subject: RE: Pros and Cons of a 02 mx 240
Byron, WY
Do a search on this forum. There are a lot of comments. Sounds like most guys like them. The main complaint is the hydrolic line that runs under the cab. After a few thousand hrs it gets a hole rubbed in it and you have to lift the cab to fix it. Check to see if this problem has been fixed.
