Posted 6/7/2009 12:51 (#735616 - in reply to #735601) Subject: RE: J B Weld on radiator
Mid Michigan
I would just solder the stem. Clean it with some sandpaper and hit it with some muriatic acid on a Q-tip and use some acid core solder and a torch. You will have it fixed in two seconds.
