Kansas | I know you said the simulation mode is turned off but also make sure the other simulation options that are grayed out are also off. You may have to turn simulation back on to get those unchecked. If that is all satisfied and it still is showing you that after you turn simulation back off and do a power cycle then you probably need to try updating the firmware in display to a newer version that way it reflashes/upgrades the Nav 900 also. If you just reflash the same version on display it wont do anything to the Nav 900. I assume you have this but the Nav900 will need to have the CAN Autopilot unlock in it. | |
