| You will need the 12 section box as well as the master switch box with the 750. Sounds like you may have that lying around.
If you want to replace the raven controller and do Rate and Section control with the CFX-750 you can use PN 99104-00...If you want to keep your existing raven controller for rate control and utilize the 750 for automated section control you can use PN 99104-01.... Both the same price
https://www.vantagenortheast.com/collections/field-iq-controllers-an... | |
