Northeast Louisiana | Neighbor had one on his 4020 three point hitch to where he can lower it all the way to the ground and hook up to a trailer hitch on the ground without getting off tractor. He had a rope to pull to raise the pin and release the rope to insert the pin. Works very easy. It was factory made and blue in color that I remember.
Here is only picture that I can find but it’s on the trailer instead of tractor end as the neighbor’s was much heavier made than this one. The idea is very similar. You probably can pattern the idea to fit the skid steer. | |
