Hiawatha, KS | Ag Leader 2500 is the same as the Outback Guidance A320. You can certainly call Outback Guidance and get a replacement whip antenna. You will need to know the MHz of your antenna (400MHz or 900 MHz) before you order. The 900MHz antenna costs $100 and the 400MHz antenna costs $115. Call 1-800-247-3808 Mon-Fri, 8am-5pm CDT. You can use option 6 or you can speak with a Customer Service/Tech Support Specialist if you have any questions. | |
