cropsey, il 61731 | I have a geoace but it came with a 900 radio compatible with a paradyme. It doesn't work with my mojortk consoles. It does not have an internal radio (which would be great to find). I need a wiring diagram/pinout of the power/external radio connector on the geoace. I have a digi radio that should be compatible with the mojortk, but it has a serial connection and I need to get from that to the geoace (and provide power to both).
I'm going to have to set the digi radio (I assume via the serial connection and software from digi?). I need to set it to send the geoace the correction information in a format it understands. Anyone know how much of this is plug and play (baud rate and few other settings) or is more required?
I have the Leica user manual, but it isn't much help. thanks | |
