Posted 10/20/2021 08:57 (#9278237 - in reply to #9277698) Subject: RE: 8320r oil leak
Northeast Iowa
its a know issue with them that the dampener moves out of the breather pipe and then oil leaks out. what you need to do is put a few shims on the breather tube thats in the middle of the input shaft so it sticks out further. also would replace the dampener since you will have it out already and im sure its soaked in oil anyway
