West central missouri | It will be the most time consuming, but take the seat out. There is a metal strip with several small bolts that goes between the cab and the metal shield that fits in front and top of the fuel tank. After the metal strip is removed you should be able to remove the shield. There are several small bolts that anchor that shield to the inside of the cab. There probably will be silicone sealing where the different metal pieces meet. Once the shield is removed, the tank is exposed and can be lifted up and back after disconnecting the fuel line. There will no doubt be many years of diesel soaked dirt between the tank and cab as well as distortion of the tank. An air nozzle and patience...
Edited by timbernt 10/17/2021 21:54
