Northwest Mo | Any braided original lines replace. Does it make a difference on fuel level or could be in tank. If there is a water sensor attached to filter bottom, make sure it has a o ring were attached. I solved a 6410 problem one time by putting a check valve in the supply line just before fuel gets to first filter. Cheap fix. If they suck air any place it is a problem. Even a tricky crankshaft sensor can cause problems. GOOD LUCK | |
