Maugansville MD | Bbi has been doing this for a while now. You don’t need a John Deere rate control just get your spreader with the ic18 computer and valve on and the cable that connects directly to your plug on the back of your tractor. Once you plug it in it will come up on your 2630 with a spreader control and you set that up and your good to go. It will adjust the speed of the net based on ground speed and what your desired rate is. Hopefully this helps! | |
