Southeastern Tipton County, Indiana | long_johns - 10/17/2021 06:52 Also if I take a test light and jump from a hot terminal on the cab solonoid to fuse 7 I think, the tractor will start and run fine, just no dash lights
You need to be making your checks at the key switch.
(Magnum 7100 Cicuit Breakers and Relays (full).PNG)
(Magnum 7100 Fuse Block (full).PNG)
(Magnum 7100 Key Switch Schema (full).png)
Attachments ---------------- Magnum 7100 Cicuit Breakers and Relays (full).PNG (48KB - 30 downloads) Magnum 7100 Fuse Block (full).PNG (68KB - 39 downloads) Magnum 7100 Key Switch Schema (full).png (43KB - 32 downloads)
