Posted 10/16/2021 14:15 (#9272148 - in reply to #9272064) Subject: RE: JD 7720 Chaff Spreader
You can probably find instructions online. Reel return line supplies the spreader, then the return from the spreader plugs in where the reel return was going to the combine. Using the cornhead, just plugs straight into the reel circuit. Use hydraulic quick connections and use female and male on opposite sides so no guess work hooking up.
