Near Intersection of I-35 & I-90 Southern Mn. | I decided to change the oil on the front hubs on one of our 8xxx tractors. This requires stopping with the drain plug on the bottom so it can be removed to drain the oil. I was alone and wondered how many trips in/out of the cab it would require to get the drain hole on the bottom.
To my surprise I got out and checked and the left front was almost directly on the bottom which was close enough to drain that side. I checked the right front and to my utter amazement, it was directly on the bottom. No trips in/out of the cab were necessary. |
