Posted 10/16/2021 09:03 (#9271687 - in reply to #9271453) Subject: RE: Case ih 8010 power
mn
That's exactly what we found out. It is the rotary screen causing the problem. Any time we start loosing power, we clean the screen! Problem solved. This black dust or fungus that the corn has in it is worse than you realize. Look at how black your combine is! Now add in humidity and it seals off the air flow of the rotary screen
