Search Forums | Classifieds (44) | Skins | Language
Pro 700 and drill problems...
Rich7241
Posted 9/15/2021 00:06 (#9220909)
Subject: Pro 700 and drill problems...
So the whole isobus and TC is working, it talks to the drill happily.
But on the headland line on the maps it will pass over the line without shutting the seed drive. It was happily doing it when the beans where drilled, but can't get it to do it. Have checked the boundary settings and the early control. All are set. Have checked the wiring on the drill. When the drill is used manually and lifted it shuts the seed off.
But doesn't do it with boundary controls.
What am I missing here.
I've tried to give as much info as i can. I've looked through ghe books and the set up is exactly as it should be.
Thanks in advance.
