SE IL Mt.Erie, IL | I just recieved my FMX and remembered reading that there as not a way to delete things on the FMX. Thought this might help someone that has a hard time downloading things from Trimble. This is copied from page 389 of the user manual from Trimble.
Deleting selected data from the internal memory
C CAUTION – Deleting data is permanent. You cannot undo the deletion or restore the
data.
1. From the Configuration screen, select System and then tap Setup.
2. If necessary, enter the administration password and then tap OK.
3. Select Data Files from the list andn then tap Manage. The Data Files screen
appears.
4. Tap Data Storage. The Delete Data Storage screen appears.
5. Select Internal Memory from the Select Storage drop-down list and then select
the Fields tab.
6. Select the item to delete from the Client, Farm Field or Event drop-down lists and
then tap Delete.
7. When prompted, tap Yes. The data in the internal memory is deleted.
Deleting all of the data from the internal memory
data.
3. Select Data Files from the list and then tap Manage. The Data Files screen
appears.
the Advanced tab.
6. Tap Delete All Fields, Delete All Events, or Delete Diagnostics.
7. When prompted, tap Yes. The data in the internal memory is deleted | |
