Posted 7/24/2021 17:40 (#9127303 - in reply to #9127127) Subject: RE: Deere 7200 seed meter, How do you remove seed disc lock spring
thumb of mi
It just presses on. They make a special puller for it but I use a small posi lock puller. Any small puller would work just get the jaws between the spring and top shoulder. You may want to consider a new hub and spring. The new hubs are machined flat and the new springs are stronger.
