Manitoba, Canada | my caseih tech support has been mulling over this for a few days now with no answer, so ill ask the folk who use this stuff on a regular basis...
have a customer with pro600 (v21) for guidance in a spx3330 sprayer. when using the Field guidance pattern (Headlands) the 2nd/3rd headlands wont generate due to tight corners, 90degrees (error ag-444 i believe).
anyone using a pro600 and found a way to disable or bypass the Tight Turn setting so that the guidance will drive straight into a corner and not try to round the path to a more driveable line? lowest number we can get on the Turn setting is 180' (120' boom + 1/2 length). at the present time the 2nd headland cant even generate a corner due to the 90deg so there isnt even a guidance line to follow along he has to try and follow his coverage map for the 2nd/3rd headlands...and without a marker of any sort on 120' thats kinda hard to do (i tried). | |
