Sunnyvale, CA | It is best to hook up a relay to the Raven boom switch and use the relay to switch the coverage logging (white and black wires on cable 52033 or 62749.) In Version 4 we added the ability to change the voltage sense ib tghe white wire. You can hook the white wire to the boom switch and change the sense of the input from Active Low to Active High. (Wrench > System > Guidance >Coverage Logging > Set to Switch. Then a new menu item will appear Coverage Logging Input Set to Active High. Then to start coverage logging the input pin is raised to 12 volts (vehicle power), the coverage logging will start. If there any strange grounding issues on your vehicle and you see funny behavior when using the Active High setting to the input pin, then you will have to use the relay and Active low. | |
