| So if I put the ez guide in manual mode and leave the EZ boom on rate 1 it will spary the entire headland without shutting off to early at the end? --- Yes
Will it start spraying as soon as I turn on my pump?---It will start when you turn your main boom switch on
Could this solve the problem of it shutting off when I loose satelite signal on the headland next to the woods? ---- Not sure on that one.
Good luck
