IL | Just wanted to let you all know that you need to check your position update HZ. It should be at 5hz and for some reason the new update is changing it to 1hz. This will seriously degrade the performance of your EZ500/EZsteer. I have seen a few people post about the issue on here. It changed all of our EZ500s back to 1hz. To check your settings go to the tool, status, and then gps. At the bottom it should have your setting which should be 5hz but the update changes it to 1hz. To get it back to 5hz save all of your configurations and everything and restore your defaults. I am surprised there hasn't been more people talking about this and I have seen several people having issues getting them calibrated this spring and this could be why. Anyone else seeing this? Trimble should really let people know about this and correct it because they won't drive nearly as good with that setting wrong. | |
