Grandview, TX | I bought 5 new raven/on off motor valves in a manifold setup like in the picture below. I installed this on a floater that I changed over from air shutoff. A raven 450 is controlling these valves and I installed a new wiring harness from front to back
Now that it’s all together, I put the 450 on manual to test it. What’s happening is each section will turn on and spray normal when I turn the 450 main boom switch on. When I turn the main boom switch off, section #2 will turn off completely, but the other four sections will not turn off fully and keep dribbling or spray at low pressure.
I know it’s valve related problems because I’ve swapped outlets around and those 4 non working sections shut off completely when hooked to that #2 motor. Also with the master switch turned off and the pump still running, if I turn the pump off, the dribbling tips will stop immediately.
Any idea what my problem might be ?
Edited by Aggie Farmer 6/9/2021 20:30
(B5F0648D-7372-4F19-8C42-55BF2DDB2777 (full).jpeg)
Attachments ---------------- B5F0648D-7372-4F19-8C42-55BF2DDB2777 (full).jpeg (109KB - 47 downloads)
